Friend and I went to a kawi dealer chasing parts for his bike today. I step over to the 10r and wowee that's a sweet color combo. I feel the lever; pull the rod; found the rod solidly hooked to the table head; and zip for movement at the cage; smooth all the way. So can you move the shaft N-S-E-West kind of X? = Zero movement. If you wiggle a hair?
OK, I'm thinking this through and walking the logic here on this needle locker. Couple of problems I can't quite get past on the theory yet.
Apply Theory:
1. Find paper drinking cup.
2. Find a small aspirin bottle [you'll need later]
3. Find a magic marker.
A. Write 0 + 360 at the seam of the cup, the plus being the line thru the center of the cup.
B. Write 90 at that degree at the cup.
C. Write 0 at the top of the aspirin bottle so both 0's of the cup and cap face you.
I. Drag around in a circl both cup and cap so they touch as they roll on each other.
II. Stop at the 90 degree point or say, find the arch the rod makes, and if it's less than 90, stop there.
III. Theory says this is going to WEAR LESS THAN MR. 360 SAID IT WOULD TURN. No way hose say is this theory good enough you hear some lame 360 goes the spin of the needles?
Why does zip-tyeing the clutch lever, cracking that perch airgap cause no binding of that needle? I have to make the theory match the facts here and still I have questions.
Pin pattern. I think I explained how the pin does not 360 but wears that edge to a short throw around the pin? That part gets eaten away. The heat/cold movement. What else could it be?
Show me the rod in the cage move, I'll show you junk against new.
In cool down mode, straight linear contraction of that needle cage, why does it bind (lack of clearance between needles and shaft) if cold there is plenty of clearance? Is the needle imprint in that new lever shaft the cause of that bind or a symptom of the bind? Chicken or the egg abstract?
Chicken or the egg theory? You got it.
No shit, this will work.
The egg: Blow your cheeks up. That is the egg. Place your hands against the blown cheeks. That's your distance in the cage. Tight against the cage and rolls like an egg.
The chicken: Let the air out of your cheeks. Do no move the hands where they lay (pun). See how your gap in the cage has your flat cheeks rolling up to one side of the cage? The air moved down to your jowls and sorta look like a "chicken lick'inn is lick'inn chit can!" < Trivia line... From what movie?
* Last updated by: Hub on 6/29/2013 @ 6:52 PM *
