On a carb, you pull choke, it either lowers a flap so the vacuum pulls out more fuel to even the vacuum of 1 atmosphere. So the ratio is going to be more fuel under choke conditions. If it was another type choke system, some use a heat sensor, a pintle is pulled out of it's closed position, exposes a large fuel metering hole and this feeds fuel to the engine via no choke but massive flow in choke mode is again, notice more fuel is more fuel, not an open main plate via the actuator in choke map mode.
The morning map is just that. It moves the main slide open, notes all the other sensor inputs like water temp is behind the engine cylinder. The air temp sensor is positioned in one of the service doors. The intake air pressure sensor is the same sensor used under the seat and you can tell the bike is open loop because of the 02 sensor replacing that seat sensor and when you see the 02 at the pipe, this is closed loop.
We have an open loop bike for tuning purposes. If we use a lambda based engine feed (02) we are stuck with the system always remaining in lambda or ideal 14.7 psi. In other words, the 02 is a toggle switch, you gas the throttle, the demand goes into open loop. The 02 now corrects the rich setting caused by the X demand [throttle opening] vs. Intake demand pressure is Y. The final fuel feed is always running on and off rich/lean back to 14.7 lambda.
So when I said to turn the key on, no engine start and a cold engine so the morning map ratchets the sub throttle, opens the main plate a tad, we are stuck in morning map mode is a faulty ECU [IF] the actuator is stuck open when key is turned off. So no need to lube if turning the key on ratchets the sub/main open, you turn the key off, the ratcheting goes home.
It says the electrical part is moving the choke mode off the lookup map chart. It is now in close mode. If a switch was corroded, it stops sending in a recognized signal, sets the code, you have:
1. A broken wire.
2. A wire out of connector.
3. Corrosion that sends in a different number being it is in a resistance mode not sending in the required number and then sets code. But this is not the case. I do not see threads with sensors failing due to corrosion all over the world is the different corrosion happening near sea level, winter mountain environments, the bike in the garage with the dryer setting off all that condensation in the garage so it settles between pins and blocks the frequency? I don't think so. Think of corrosion on the battery posts and they still start the bike, take a charge, etc. It has to be so severe so as to cause itself not to feed the starter being the corrosion do not send in the next move. Are we on the same page yet you go running around for nothing?
Since you can ride the bike around, won't overheat like it was starving for fuel, it seems like a physical problem? I could be wrong, but you'll finally figure out via air leak, mechanical hangup, or something electrical. Why am I not chasing electrical? No codes present. Once you understand how the electrical system is a preset like a toaster, you just can't throw in some other resistor or remove a part from the toaster and think it will work the same. It is a preset like the computer bike. If the sub sensor drags, sticks, does not keep up with the TPS input, is not one tripping over an out of balanced input signal? Would not the sticking of said shaft/sensor set a code? Yep.
So a novice is sending you on a goose chase as you snap connectors clean off going after a suggestion that is not for this issue. It's like saying the bike does not run, but someone says to clean the carb but never suggested to check compression first? So the bike does not run after the carb clean. It was a tight valve, stuck valve, frozen rings the bike sat and rusted up in said environment. See how one can chase tail if they do not walk out each suggestion from a far?
I can see it from here is one runner upper can fuck up a simple diagnostic is 30 pages long of shithe fuck down you clueless fuckers of the net. Since 1999 not one tech could come up with WATThe fuk the tre was doing? Too fucking simple is the answer. Book savvy make one not savvy if they flip thru the pages and do not read between the lines is you need to know the basics before you open the book thinking your answer is there like some think there is. Those assholes you put in their plate is throw the book athem. LOL
