[i]because there is a power drop-off if that dyno was in my garage I'd have snowflake set for that day's map. I do not chase 150 or 160 degrees for HP. If HP is a 230°F = She is tuned to HP, not engine temp my thermostat my nuts less damp to turn the oil a chocolate color shake [that runs too cold] to burn off the condensation in the crankcase. That was one example you remove the thermostat kind of variable. Ya blew a step to tuning, not a head gasket.[i]
Well if you had my dyno in my garage you would know that your 14 does not make great power at 200* It makes its best power around 155-160 anything over that you start to lose a good bit of power. I will post some runs and show you. Your a/f want change much so your tune is not off from 160 to 200 your I.A.T's go up your computer compensates for the higher temps.But it can only compensate so much. This is why your 14 feels like it has 20 more hp in the winter than the summer I.A.T's are way down Motors love cold air. Cooler running motor means cooler air box cooler air box mean lower I.A.T's wich means more power.
This is why you put a Ice pack on a supercharger to cool it down. so it does not heat up the air comeing in. And why you put a spray bar on an intercooler to cool the air down before entering the intake. wich means big hp increase.
* Last updated by: justins07zx10 on 5/25/2011 @ 7:23 AM *
PcIII
BMC Race
Full S/S Muzzy M10
Scotts Damper
G.I Pro w/tre
Z/G doubble bubble
16t sprocket
speedo healer
More to come...
