I am about 98% certain the gasket still leaks even after the washer trick. It is slowed down considerably but there is a small amount of oil that collected under the bottom edge of the front left corner. I ran my finger over and it squeezed out. Also, I see a film of oil has crept down the front. I wiped that pretty thoroughly. What I see must be fresh oil.
Good news, not enough leakage to collect a drip on the header stud. Prolly, if the heat insulator rubber plate was on there, I would never know.
We'll see what happens in summer. Too cold to bother with it now and it seems mostly fixed anyway. Have to monitor the amount of oil that needs to be added. Next valve clearance check, I will be going with the new gasket and I will get new rubberized bolt washers as well. Maybe even apply liquid gasket like edge suggested. Prolly not do the washer fix the next time unless it still leaks in which case I will prolly just give up and accept it as being a "less than perfect but a lot better than it was" job.
* Last updated by: Rook on 12/7/2011 @ 3:28 PM *
