Hub said..."No matter what you added to the thread, I don't know, did you have to?"....in other words...stay out of anyone's threads?That's what yer saying?
No, that is not what I am saying. What that meant was, contribute, but where are you going with a bent axle input? Then yeah, shithell down!
Suck it up badboy...I add what I want...whether YOU approve or not...someday...you'll get it.In the meantime....the OP and others JUST MIGHT benefit from my observation of a wrongly installed axle down the road...CAPISH?Good.It's not for you oh Master Tech...it's for him...and others.
If you had a better eye at looking at a photo, you happened to need Mr. Master Tech Can handle the view of you missing the clue about a hole and a cotter and distances there of in a photo. If that was not enough for you... She IThe Fuck Down Clown! Until you get a clue about how valuable a bent axle info will be if the OP and shove that thing up your asstraight ass day is all day withit is you getting hit with that bent millimeter of yours IS!
"You had no clue how the carrier got turned around"....geez...I wasn't talking about HOW the carrier got turned around...wtf you assuming what I did or didn't 'get' about the caliper turning like it did?
Because it questions why you would bring up a bent axle that can swing the cotter pin down it's throat is choke on that part of the parts is parts you don't see, little rubber red nose. HOw the howling do I know how you keep that from falling off, sure beats me?
I MENTIONED what I see as something very wrong with that install...
You mean, something so common, even happened to me with all the tire replacing. Schooled me is did not school you I see.
NOT how the caliper got turned.
That is why you need to pick your tech threads carefully. I only know what I know is answer a tech question that I can handle. I did fuck up in that area. Schooled myself as to brake stay(s) and all that tapping of the brake noise. Did not the OP point that out? Obviously, what else would there be to discuss; is not how the caliper got turned around? After you get done with it, we hear plenty. We hear from the 3-4 shifter guy letting you know about how your gears grind. So just relax if I or ROOK corrects you on an assembly point. We pointed out you are not too qualified to be discussing cotter pin position, let alone where to line up parts is parts like the OP showed you. He's even going to pee forum a wheelie for you so the OP can close with the parts is parts is good to go. No bent axle here. Every cotter in place here is until you show up and explain it. LOL
I think I can figure that one out.
I think I showed you a bent axle, a wheelie, and a cotter pin just get worse is how your posts end up. Clown the OP is dumb dem down.
If you don't see a problem with that axle cotter/nut line up...fine.
Not only was it fine when the original situation happened, even the OP got the cotter distance right. Is there is no other way that axle fits unless you are too stupid to see it. You brought that up as if another bent axle is part of the diagnosis? Well, is it or is it not? No, it is not. The OP did not mention how hard the axle went in did he? How come you did not assume that with the bent axle? I and a few others would agree with you if it was bent, hard to go thru, and don't forget the nut threads. I'd be the first. But it was a missing part, and no mention of threads either. It was, and Danno is going to choke in dis, but it was absolutely a missing spacer insert. It was not a bent axle, say it. Yes or no it was a missing part so in the absolute it was a bent axle instead. Say Danno? Did the part speak in the absolute or a bent axle? So, in the absolute way of saying it any other way, was that a waste of reading that mess? Yes or no, was it a bent axle after all it was [YOU] that said it and it was done was that post back on page one. But no, some sap, "I'm gonna say what I wanna say is look stupidoing it." Is that not a GAS'did question?
Glad you're not working on MY bike.
Be those dirty forks that were never changed as per manual to remain compliant with the warranty schedules... "Whichever comes first." What other messes would we find that were neglected? I can name two more.
I see one....
No. I said I see more than one and can run a list of what you think you know without doing the job. In other words, you'd be discussing sex and still be a virgin. How your bent axle was up someone's rear end is more, we were discussing not needing viagra. And why you would need a pill for that now at your age is still a virgin, right? No, I'm just saying how did this handjob show up and we are washing Cody off with her chrome remover kind of leave her alone... Why don't you knock first?
IDK IF it could have been a part of his caliper ending up as it was...
I don't deal in if's. We know it assembles one way. No doubt it can be assembled your way, but is that the ABSOLUTE way it goes together? No. It goes together with a bent axle, no cotter pin hole, leave the gap there on the other side, it's my bike. Glad your bent axle didn't show up with a set of tools kind of ask Danno if he'll let you work on his bike for him? You seem to not touch yours too much. Say yes or no, I hand off a tire change but can install a few wheels in my time... Say it.
I won't speculate on that...but I KNOW what I see.
It is like me looking for a pit crew. All I get are clowns thinking a bent axle is needed, someone forgot to install the spacer last set of tires. You see that kind of pit? Would you let me in on your pit, you look up and down pit row for an axle? Yes or no? I bring back a bent axle for you, and you now complain about it? Look how that wound up wit someone just runs in, gives an off the wall suggestion. Not even close to the OP's... Oh forget about it.
Whether YOU or anyone else sees it.Does HIS rear nut/axle cotter hole,and angles of the locknut in relation to the horizontal planes of the swingarm,and adjuster block bolts look right to you?
Whether YOU like it or not, the rear nut/axle cotter hole, and angles of the nutcase in relation to a bent axle down the shaft someplace, it horizontal plain as day is the swingarm adjuster block bolts look right to you? Man, that was about as bla-bla-the-bla-was-blabbing in a circle was the carrier, not the adjuster bolt with an exposure time to distort your view. What happened to the carrier not keyed in? There you go again. Off to the chain adjust thread we go. Stay with the carrier first. Stay with the 3-4 first. Stay with the exhaust pipe taken on and off so many times, you see, you hear bent axles speaking to you at night.
There's only ONE way THAT could happen...accept it or not.
IDC. What just happened?
I want to see a pic of his left side axle flange pulled out like Rook's pic.I can virtually guarantee ya..there's some scoring on the inside suface of that flange as it turned over the adjuster block.You wouldn't see it with the axle all the way back in.You MIGHT see some on the outer side of the adjuster block...but his pic there is too small to see anything like that.
What in the fuck are you still ranting on and on about your fucking ufckedupissing contest?
It turned...that axle turned when his brake caliper hit the top of the swingarm.
Says you! Even the OP said he'd do wheelies for you is all is fine in his world is story over. Only you go on and on about a bent axle, now an axle that is out of its slot? Didn't we figure out it was not a bent axle, nor an axle sticking out like how many mm is your Cody? Might asswell bring that little guy in. Why do you think I show mine? You want to see my bent axle shaft entering the waiting orifice of her wet glands are happy to see Cody, he drops right in like a greased axle are you getting something headed "UP YOURS!"
That axle nut has been damaged from probably being overtightened.
Here we go with thread damage, the cotter is in, the OP said nothing about how the nut goes on and off, just the nut that keeps adding posts about shit, say 4 pages of 'boring' shitslinging.
Look at it.
No, you look at it.
Overtightened to try and 'line up' that cotter hole with the axle slot when it had too few threads available to get the hole to be accessable enough to slip that pin through there...IDK about YOU...but I can tell ya right here and now...
Oh shit... Are you still on this crap? The theater closed hours ago. Nothing is on the screen guy. Come tomorrow.
Remove your axle(HUB).NOW...turn it 180 and reinsert into the hub..all the way in.Tighten the locknut.Tell me NOW..do the axle nut slots line up like they did with the axle turned 180 the other way?Go ahead...you're the tech.
Why don't you take that home with you too. Figure it out, come back tomorrow. I think the thread sort of ended with a wheelie kind of, "I got it! Thanks! Got it so fixed, want me to verify with a wheelie all is well, hello?"
Tell me and everyone here.Want me to answer this for ya?....I can...I've done it. I know what a seated axle looks like.And how much the right side threads should be sticking out past that locknut.
Bla-bla-bla-again I say-the blab-ba-blab'inn I will go.
That pic shows an axle that was NOT installed all the way in.
Relax. It's not your axle NOT installed all the way. Simmer down fella. We know you want to do right. The OP has got it, thanks! You bet. Righteaho. Yes sir wee bob.
Turning that axle 180 degrees from the factory setting will CHANGE the number of threads you will use to tighten that locknut.There's NO getting around that fact with double talk.Period.
Yep, double-double with extra cheeze. No getting around the bla-bla-bla when it comes to chiming in on the brake carrier. Got it. I got it. The OP's got it. Cody even got it.
And if it's not seated..it's going to be even worse....kinda like that pic.This bike aint no toy.They KNOW wtf they're doing when they match components together.
OK... Could you just calm down some? We figured it out some. I can tell you dis so far. It wasn't a bent axle. Keep guessing about that axle extension, mm.
If it's seated...even having it 180 out...you can still move the locknut enough clockwise or cc to get a pin in that hole.
CC, MM, OK, whatever you say.
So the axle isn't marked with a hash mark showing which direction it should be sitting as long as it's seated in the block(the hole will always be exactly centered).BUT...you add a not seated axle..and try and install that locknut and pin in there...good luck...you're gonna damage something trying to line things up.Try it...don't take my word for it.
So from dis, you could get a cotter pin in there now, is it could not before? Take your word for it? You gotta be kidding, right?
Could someone tell him the OP sort of figured it all out?
* Last updated by: Hub on 6/6/2012 @ 1:48 AM *
