Page: 1 2 3 4 5
Thread: rear brakes
Created on: 06/03/12 12:32 PM
ChuckA
ChuckA's Gravatar
rear brakes
06/03/12 12:32 PM
guys can some one post a pic of what the brakes connecting to the rear tire should look like , i have the hoses and i think they are kinked, i looked at the pads, and it looks like there is a lot of meat still on the pads, just need a pic of the rear brake assembly, thanks, i will post a pic when i get a camera, that works thanks
My corvette 6 speed is nice, my vulcan 1500 is comfortable, my zx14 is a freaking MONSTER.
RE: rear brakes
06/03/12 12:43 PM
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 12:47 PM
does this look like the wiring and the hose are ok, because i think they may have been kinked, let me know thanks
DogoZX
DogoZX's Gravatar
RE: rear brakes
06/03/12 12:53 PM
^^^, Dude... Pay someone to turn wrenches for you.^^^
RE: rear brakes
06/03/12 12:53 PM
Aw geez....Get that outta there and reinstall.OMG...that slot ya see there...that goes INTO the swingarm slot.IDK how ya got er in there like that.DO NOT RIDE THAT BIKE with it like that!PLEASE!!!!!!The caliper needs to be at the bottom...the slot riding in the swingarm 'block'.Hoses need to be coming around over the top(they will be once ya get that caliper in there right.SHEESH!(not making fun,okay?)I just had NO idea it could be installed that way!!!
* Last updated by: Grn14 on 6/3/2012 @ 12:58 PM *
DogoZX
DogoZX's Gravatar
RE: rear brakes
06/03/12 12:55 PM
I know, I'm a dick... but seriously... You gonna get hurt.
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 1:14 PM
how the fuc- did that happen, i will try to move the caliper, i just dont know how the hell that happened
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 1:16 PM
should i unscrew the bolt that holds the rear tire and the move it back?
RE: rear brakes
06/03/12 1:25 PM
Get er on a stand...remove the axle(slide it over..the threaded tip flush with the bearings.You will need to take the caliper all the way off to do it.....Slide the slot onto the swingarm block in there...all the way in.Slide your axle all the way across now...into the caliper hole and swingarm axle hole..Recheck everything.Make sure your axle alignment is still okay...then retighten that axle nut...cotter it of course.I just hope you didn't somehow bend your rotor?....You'll know soon enough I guess.BEFORE you RIDE...pump the rear brake lever several times to get the pressure back up.
MAKE SURE the axle is fully seated on the OTHER side...with the adjuster block fully seated againt the swingarm...and the axle sitting in the adjuster block all the way.Same with that other side...the brake side.Your spacer is in that side(the hub spacer)...yes?Make sure it is....to the inside of the caliper hole.Hub...spacer...caliper...swingarm.. adjuster block..washer...lock nut...cotter pin.That's how it should be.You might want to put something UNDER the tire to support the axle/wheel from dropping down while the axle is out of that right side swingarm hole...I would.
* Last updated by: Grn14 on 6/3/2012 @ 1:38 PM *
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 1:57 PM
to all who helped i need to say a great big THANKSi put the caliper back were it belongs all works good again, thanks again for all who helped
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 2:16 PM
thanks again especially grn14
KoflaOlivieri
KoflaOlivieri's Gravatar
Philadelphia, PA
RE: rear brakes
06/03/12 5:16 PM
Wow, you are lucky you didn't get hurt.
NINJA ZX-14 MotoVlog
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 6:33 PM
does anyone have any idea what would make this happen? i plan on getting the bike looked at as to WTF made this happen
very strange indeed
Jomo1
Jomo1's Gravatar
RE: rear brakes
06/03/12 7:20 PM
Hey Chuck did you just put a new tire on the back? That's really odd to see the caliper flipped in the up position! Good luck with the fix.
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 7:36 PM
no i have not , i locked up the rear and this happened, i will keep you guys informed as to why this happened, hopefully this was a rare thing
hagrid's Gravatar
RE: rear brakes
06/03/12 7:39 PM
Who was the last person to re-install the rear wheel?
Its obvious whomever that was they didnt get the slot on the caliper bracket to engage the tab on the swingarm.
Let me guess: you had the rear tire changed... they gave you back your scooter... you hit the road and the first time you
hit the rear brake you hear/feel THUD!
Yoshis!! GO NINJEE!!!
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 7:55 PM
i bought the bike that way and yes when i heard that THUD, i was like WTF, and then noticed no rear brakes, i just hope the brake fluid wont spill all over the place, i did see some fluid, crap crap, crap
* Last updated by: ChuckA on 6/3/2012 @ 7:55 PM *
hagrid's Gravatar
RE: rear brakes
06/03/12 8:17 PM
Brake fluid is escaping?!?!
DO NOT RIDE THAT SCOOTER!!!
Either the brake line is ruptured or the caliper casting is cracked... or both.
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/03/12 8:24 PM
does the brake fluid use go on both front and rear or are they seperately fed?
BigD
BigD's Gravatar
RE: rear brakes
06/03/12 8:41 PM
I am sorry but this guy can not be real about this.
hagrid's Gravatar
RE: rear brakes
06/03/12 9:09 PM
They are separate circuits.
The rear brake reservoir is under the seat.
RE: rear brakes
06/03/12 11:35 PM
Hagrid wrote..."Its obvious whomever that was they didnt get the slot on the caliper bracket to engage the tab on the swingarm"...yes...it COULD happen...it could.It rotated with the wheel rotation(when the brake was applied)...so ya...it happened IMO.And yes...it WOULD thud pretty bigtime once it smacked that swingarm.
It looks to me like there may be some damage to the bottom arc of the rotor there...some gouging or something.You might do well to get that rotor checked as well...If it's bent...yer gonna have even MORE problems.
* Last updated by: Grn14 on 6/3/2012 @ 11:37 PM *
bigwilliezx
bigwilliezx's Gravatar
RE: rear brakes
06/04/12 12:41 AM
WOW... that sucks - bent the retainer bracket to hell! Glad ya got er' fixed back up properly!!!
Life may begin at 30, but it doesn't get real interesting until about 150... Ride or die!
2010 SE(Black/Titanium) - PCV,Piper X Filter,Dual Rad Fans,Muzzy Rr Fndr elim,Pro Tek Frm Sldrs,PM Heathen Wheels,PM Chrome sprocket,Corbin Canyon Dual Sport seat,Brocks CT Duals,Shorai LFX18A1-BS12,CRG Roll-a-Click levers,Cox Radiator Guard, GP Thunder 8500k 65W Hi/Lo-Beam Xenon blbs,Engine Ice,Flush mount front turn signals,MRA Spoiler Screen,HeliBars 1" bar risers,Goodridge Stainless Steel Brake Lines (F/R) and a Powerbronze Hugger fender - More coming!
2009 ZX10R CBO,Saddleman Trk Seat,Piper X Filter,Cox Rad Guard,Shorai battery,CRG Levers,Galfer SS Lines,Driven SBOP,Yoshimura Frm Sldrs,Speedo Healer/X-TRE/17-44 Driven grs,Bazzaz ZFI-QS w/Map switch,MJS Perf Ceramic Coated Race header,Akra SS mid pipe/CF Evo Slip on,R@G Racing Case/Front Axle sliders,Rizoma Veloce L Mirrors,Hyperpro Steering Damper,MRA Spoiler Screen,Servo Elim,Evotech Exh Hanger,CF Rr Hugger(Ohlins,Marchesini,coming s
buck20
buck20's Gravatar
RE: rear brakes
06/04/12 1:44 AM
I've seen it all now! He is lucky that could have got real ugly.
* Last updated by: buck20 on 6/4/2012 @ 1:48 AM *
To much to list!
ChuckA
ChuckA's Gravatar
RE: rear brakes
06/04/12 5:44 AM
i need to bring the bike in and get the wheel put on properly i see the bracket as to were the chock goes into
Page: 1 2 3 4 5
