For anyone wanting to install one of these Akrapovic Evolution systems on your bike, a few installation tricks I wish they had included in the manual would have saved a lot of time and aggravation. First off the parts fit on the bike was near perfect but the installation must follow a specific sequence or you run into trouble with clearance issues getting to the springs and exhaust flange nuts. The exhaust flange stub pipes bolt on to the cylinder head studs with stock nuts and then the headers slip onto the stubs and are retained by strong springs. Make sure you follow the manual here and torque the flange nuts before slipping the headers on. Once the headers are on, there is no way to get a torque wrench on there for the inboard ones as I found out. For the inboards, #2 and #3 I had to use a dog leg 12mm to tighten with. This was time consuming as you could only get about 1/8 turn each time and left my nuckles bloodied and some dents in the backside of the radiator. All this is avoidable by torquing the nuts before slipping the header tubes on. Slip the two inboard headers, #2 and #3 in place first and stretch the inboard spings into place first on each of them. You need to use a good spring puller for this as they are stout. I used my Yoshimura spring puller and the handle snapped off after about three springs....aaargh! Next attach the two outboard springs on #2 and 3, then slip on #1 and #4 headers, the outboard ones and again do the inboard and then outboard springs. I initially installed all the header tubes and could not reach the inboard springs on #2 and #3 and had to take it all back apart. What a hassle! The collector slipped onto the header tubes perfectly using the supplied ceramic grease and the midpipe link and end can fit on easily as well. I attached the springs to each and then lightly wiggled as the spring tension pulled them in and seated them against the inner collars with a nice click...beautiful. These pipes are a work of art, you have to see the welds to appreciate them. The bike screams now, this is the way it should have run from the factory, I'd say I'm within a few HP of a BMW S1000RR now on the topend with way more low and midrange. Midrange hit is stronger than my CBR 1000RR now and above 6000 rpm will run away. The CBR still has an advantage on the low end up to about 5000 rpm. Topend wise I think this thing will outpull even my ZX-14. I can't wait to get the TRE, PCIII and Ivan's magic mappng on there, maybe Friday morning. Should smooth things out considerably, especialy down low but I doubt if it will add any more power.
* Last updated by: Kruz on 6/28/2010 @ 2:00 PM *
