Thread: 14-R 1441cc Stroke Only
Created on: 10/11/11 09:59 AM
10/11/11 9:59 AM
She is no top model. She is just a revised flagship model. I am waiting on the side lines for the next top model. Threw me for a loop; no bore. Too bad you can't use the rod for the same piston bore on first gen. Increased big and small ends for that extra rod torque out the gate. Oh well!?
RE: 14-R 1441cc Stroke Only
10/11/11 10:05 AM
http://ninja14r.kawasaki.com/?cm_mmc=MY12NinjaZX14R-_-KMCPromo-_-HomepageBucket-_-Microsite#details/videos/8
DogoZX
DogoZX's Gravatar
10/11/11 10:29 AM
I think same piston bore is a good thing. Larger bore = thin walls = overheating. That is, unless they would have made they block wider... Glad they didn't do that either. New bike is already a little wider than the old with same piston bore... Must be from the slipper clutch???
10/12/11 6:34 PM
Anyone commented on the mouth yet?
That is TOO over the top for me. The Old 14 resembles a shark with open mouth but this is whacking you over the head. To Warner Bros for me. Should be much more subtle if any allusions to anything other than a motorcycle are made.
Still a cool bike but if there is no reason for that furrow they have that looks so much like a cartoon scowling mouth, I could do without it.
* Last updated by: Rook on 10/12/2011 @ 6:43 PM *
bigwilliezx
bigwilliezx's Gravatar
10/12/11 7:10 PM
I like the mug they put on this one - the 14 has always been different and I'm glad they kept it that way! Got lots of character! Not the cookie cutter front ends they put on Suzi's - they all pretty much look the same from the front.
Life may begin at 30, but it doesn't get real interesting until about 150... Ride or die!
2010 SE(Black/Titanium) - PCV,Piper X Filter,Dual Rad Fans,Muzzy Rr Fndr elim,Pro Tek Frm Sldrs,PM Heathen Wheels,PM Chrome sprocket,Corbin Canyon Dual Sport seat,Brocks CT Duals,Shorai LFX18A1-BS12,CRG Roll-a-Click levers,Cox Radiator Guard, GP Thunder 8500k 65W Hi/Lo-Beam Xenon blbs,Engine Ice,Flush mount front turn signals,MRA Spoiler Screen,HeliBars 1" bar risers,Goodridge Stainless Steel Brake Lines (F/R) and a Powerbronze Hugger fender - More coming!
2009 ZX10R CBO,Saddleman Trk Seat,Piper X Filter,Cox Rad Guard,Shorai battery,CRG Levers,Galfer SS Lines,Driven SBOP,Yoshimura Frm Sldrs,Speedo Healer/X-TRE/17-44 Driven grs,Bazzaz ZFI-QS w/Map switch,MJS Perf Ceramic Coated Race header,Akra SS mid pipe/CF Evo Slip on,R@G Racing Case/Front Axle sliders,Rizoma Veloce L Mirrors,Hyperpro Steering Damper,MRA Spoiler Screen,Servo Elim,Evotech Exh Hanger,CF Rr Hugger(Ohlins,Marchesini,coming s
10/12/11 7:21 PM
40% air volume increase in mugging. Someone has to say, "Open Wide" somewhere, Rook
Donny
Donny's Gravatar
10/12/11 8:14 PM
The bike is a fine evolution of the 14!
www.drblast.com
10/12/11 8:28 PM
It is superb in every way, Donny. I can't go heavier than what I have now. Have fun with it, lady/gents. I see it moving in the wrong direction for me. I want light and quick. Fast and mean. Tell me if that is going in my direction is to add more winker weight, where I could of had a V-8. That or the winks in the mirrors to eliminate ounces. I'm down to chasing ounces off the OEM, not pour aftmrk nuts and bolts being all lightweight? That is the factory's problem.
10/12/11 10:35 PM
It looks exactly like a snake head from the side.
