Page: 1 2 3
Thread: Head gasket?
Created on: 05/14/11 06:10 PM
justins07zx10
Head gasket?
05/14/11 6:10 PM
Thinking bout doin the head gasket on this thing, just worried about the heat. My bike stays around the middle bar now. Did anyone have problems with over heating after a hg.
* Last updated by: justins07zx10 on 5/14/2011 @ 6:10 PM *
06 ZX-14 "MR. Smiley"
PcIII
BMC Race
Full S/S Muzzy M10
Scotts Damper
G.I Pro w/tre
Z/G doubble bubble
16t sprocket
speedo healer
More to come...
RE: Head gasket?
05/15/11 1:11 AM
I know some have installed the thinner gasket...for more compression.I also think they're drag guys.Not sure at all if over the long haul a thinner head gasket would be a safe deal on a mainly street performance zx14 engine.IDK.I'm assuming you're thinking about installing a THINNER gasket?
* Last updated by: blue07 on 5/15/2011 @ 1:12 AM *
RE: Head gasket?
05/15/11 2:43 PM
Say you be real careful, run a shot of WD-Pam-She lack whatever you can push down the spark plug hole; that is your 'release agent.'
Something like rubbing a tootsie roll like a tiny snake; snake it so it spirals near a valve. This is your base-crush.
You want that thinner gasket, you have the head off, the crush number, new gasket number thickness; How close you wanna tag valves you are closer without pockets being cut deeper. You finding that magic number, you do the math.
I'd be in some proportion if big engines use the 0.040" min-gap. Unless you come away with a 0.037" I'd be...
Dish close.
Then, to stop the knock, I'd have to gulp the big change. And what price is that for your little chunk of bump?
Piss'inn away your money. Are we at the 1/8th-1/4 mile gotta get what I can get? Or are you a street scraper. When the moon hitsorta.
May I suggesTThe real test tickle? Wood less brake, more trade in the gasket for a penis enlargerun for ya? Kill two birds you can bead the brakes withe bestove them LOL
justins07zx10
RE: Head gasket?
05/15/11 2:59 PM
I don't understand one bit of what you attempted to type there. HUB
Anyway,yes it's a thinner gasket. I did the thin gasket on my zx10 but it didn't run as hot as the 14 is. I was just wondering if anyone had any problems on here.
My zx10r gained 12rwhp with a headgasket if I can get close to that with the 14 this thing will get down.
PcIII
BMC Race
Full S/S Muzzy M10
Scotts Damper
G.I Pro w/tre
Z/G doubble bubble
16t sprocket
speedo healer
More to come...
Kolk1
Kolk1's Gravatar
RE: Head gasket?
05/15/11 6:20 PM
If we can get 10whp with a thinner headgasket, id be all over that.
2007 Plasma Blue ZX-14.
RE: Head gasket?
05/16/11 12:13 AM
Justin,
What your z10 says about a head gasket is you can drop it in and go.
What I said was to find the gap between a piston and the valve.
What I meant was if you lower the valve closer to the piston, it might hit and tag each other you do not get a good measurement.
What I said was to use an oil to keep a clay or a soft type of material that will hold a crush memory so you have your initial thickness of how close that valve is in proportion to how much of a clue do you need reread my rehashed cabbage I gotta repeat what is too obvious like I drop the door height from 80" down to a 40" height.
What are the odds you smack yourself right in the face but you can almost walk with part of a leg swing in the other side.
That work for ya?
justins07zx10
RE: Head gasket?
05/16/11 4:12 PM
I'm not a dumbass. I'll check the piston to valve clearance. I just want to know if anyone has had an overheating problem with the 14 and a thinner head gasket. Next time I make a post please don't comment unless you can, 1st answer my question, 2nd type like a normal member on the forum. Thanks.
PcIII
BMC Race
Full S/S Muzzy M10
Scotts Damper
G.I Pro w/tre
Z/G doubble bubble
16t sprocket
speedo healer
More to come...
Slowninja
RE: Head gasket?
05/16/11 8:09 PM
Yes, run the .018 head gasket. Yes, get adjustable cam gears. Yes, the bike will pick up nearly 10 hp.
No, the bike will not run any hotter then stock.
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
RE: Head gasket?
05/16/11 9:19 PM
I'm not a dumbass.
I didn't say you were. I say your abstract can be answered but you are either lazy or refuse to work out a science project... If I slapped a hot BBQ brick up yourear end, you would not ask, you would just bend over, you look like that to me. Blind-Tuning. No thought. Dumbshithinking. Dare, I call it assay seas to shining see?
No he didn't.
Yes he did!
And if you never got your answer? ASs yourself if you'd be lost, answer your own question with the z10? Stupiduning Tuning my 10.
Oh, I can. I will, trust me on that. You are not the only one reading my shit. In fact, you are out of the picture just about every post I answer in a more generic/concept = No Answer A CUM All over YOU!
I do whatever I want as you do whatever you like. Tell me WOTTTAWaaaa?
Tanks buttcakes, no fucking way. You will have to kill me fella. 'Litteralley!' Yul tide like worse than any sue no me. YOU do knot know me nor do I. And that is yur pro blame how you gonna cope with a recalcitrant. You see it ass arrogant, bullying, my shot don't smell.
Yes it does!
Yes it dose!
Yes you Will!
Yeastry me!
Yi can't wait!
Get a lane faggot. YOu got milk? Or you got a cigarette boat? Either way = Sink YOur BUZZZzzzz YOu are now the MARK! She how that cycle worlds around your head and not a fucking think you can dog due about it. Note: Not my monkey cry you spoil a thread I enter.
For the rest of you... I goat cheeze nut'inn foreskinedis ass head cut off in his mouth.... Back to camp pee-OOPs!
* Last updated by: Hub on 5/16/2011 @ 9:23 PM *
RE: Head gasket?
05/16/11 9:30 PM
* Last updated by: Hub on 5/16/2011 @ 9:31 PM *
RE: Head gasket?
05/16/11 11:39 PM
Justicennnn,
Once you turn around and see who's gaining on you, you more lost the sighting up ahead. Dishisore sing post I toast you and your branch-monkey. You make waves on me guy... It's endurance raining on your parade. Anyone that cries about anything but bike, slow help you... Stay fuckiss you little wee knee.
If you want a how-toot un-bunch your diaper, take a basic course in man up and read up is for dummies like you is how I write for. You are that stoo-dense not student. Relax like your other buddy. No nanzzy manzzy panzzy sissy can't handle the color! OH, how gross someone set it to silk.
And the sheer. It pulls my Poise INN Pending. Write where I wanted it, I, I, wannna WAAAAAAAAAAAAAAAAAAAAAA!!!
(Runs around the room with a dick shun fairy)
* Last updated by: Hub on 5/16/2011 @ 11:42 PM *
justins07zx10
RE: Head gasket?
05/17/11 8:22 AM
I hate fucking bitch ass keyboard warrior like you. You fucking fat punk bitch. I asked your fucking retarded ass nicely not to comment on my fucking post. Now I know why there is nobody on this fucking site. Your bitch ass is as stupid as I thought you were from attempting to read your other retarded ass post you stupid fuck. Get a fucking life get out from behind the fucking p.o.s computer you got and do something besides live off fucking wellfare from people like me. 0
I didn't fucking ask about piston to valve clearance I'll check that, I asked about overheating because I feel the zx-14 runs a good bit hotter than my zx10 did. I don't want to waste $60 and a few hours of labor on something I might have to take back off. Simple question right If you don't know the answer and perfectly content with your stock ass bike stay the fuck off my thread!!!
And thanks Slow appreciate the answer to my question. I already have the adjustable cam gears. tried these a few diffrent ways. I think I'm going to try something wider like a 108/in 105/ex. Or so what you think.
PcIII
BMC Race
Full S/S Muzzy M10
Scotts Damper
G.I Pro w/tre
Z/G doubble bubble
16t sprocket
speedo healer
More to come...
soldier
soldier's Gravatar
RE: Head gasket?
05/17/11 10:35 AM
Wow! Im new to this forum but already Im turned off by threads like this. Im a member of quite a few bike forums as Im an avid sport bike rider and I've never seen posts like this allowed. How about we have some moderators to suspend people that get out of control with language and such. Its disappointing...
"Wars are not won by fighting battles; wars are won by choosing battles" - George S. Patton
"Often a dash of judgement is better than a flash of genius" - Howard W. Newton
Current:
2009 ZX-14 Monster Edition, Vance & Hines slip ons, ZG double bubble
Past:
2001 Yamaha YZF-R1 Champions Edition #868/1000
1986 Suzuki Cavalcade 1400
1978 Suzuki GS550
Slowninja
RE: Head gasket?
05/17/11 11:02 AM
I'll have to check, but i'm pretty sure i'm running 106/108.
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
Edgecrusher
Edgecrusher's Gravatar
RE: Head gasket?
05/17/11 11:24 AM
From my experience, most people on here are mature enough to ignore stuff if they don't like it and just respond to people they want. It's what makes this forum better than the more complicated and hyped forums IMO. I'll agree Hub can be a pain in the backside, but he's been around here before most and he is really trying to help in his own way. I just think of him as the idiot savant who has his own language. But he's usually only relevant to people who are motivated to think, hence why he uses his code. It's just unfortunate he has no sympathy for a lack of humor. lol Not to say I believe he's right about everything he says. I just worry for his neighbors children sometimes....
RIP 08 Special ED ZX-14
RE: Head gasket?
05/17/11 11:47 AM
You have kids jumping in your yard going gay feet tea, and yes, better lockup your kids! My kid would never act like that. Mess up someone's home.
Dishere is home base. You have zero clue about what you're doing. You don't want to listen. You act like you can't think for yourself. Your ass is getting wiped by the 'resident 1320.' He's changing your diaper.
Whatever you say, I can take your abstract and kick the can with it.
Say, I have an 8oz. can and I have a can opener here. Can I open some big kaneye, can I? I know the beansay I fart about 10 more times. I know this one has hose says in the recipe being hot but never overheated with all the mods on the bike, I just wanna know if my generic can opener can open this can of worms?
Once again, you come barging into someone's home, yells for them to leave. Pretty funny. Then he opens the fridge of slow's garage wearout, I see is aspirin is your second course. Stay the course... A diaper change will be here shorts wee-wee need a changing now?
And no, you will have to remove my password so I do not show up on any fucking thread I want. How you like me in your bed with the old lady? Beer cold enough for ya?
RE: Head gasket?
05/17/11 11:50 AM
Soldier,
Dishit is the war room. YOu'll not find a better crew. UP to you.
soldier
soldier's Gravatar
RE: Head gasket?
05/17/11 12:12 PM
Don't get me wrong, Im not personally offended by the language. I mean hell Im in the desert right now with an MP company so Im used to it lol. I just think we should stick to topics and not take personal shots at each other. I have already learned a lot on this forum and will def be sticking around. Just thought Id throw in my 2 cents...
Current:
Past:
1978 Suzuki GS550
Edgecrusher
RE: Head gasket?
05/17/11 12:53 PM
good for you. and thanks.
RE: Head gasket?
05/17/11 2:32 PM
WHEEEEEE....it's a LOVE connection.I noticed it right off!
BTW Soldier..wherever yer at there....stay safe,keep yer peepers open.Got that bitchen 14 waiting on ya...she's just itchin to go for a romp!
Friend of mine was in an MP company.They were in talkin to some Iraqis about somethin...guy(Iraqi) standin next to my bud pulled a friggin dagger....no damage...my bud subdued him...but.... WTF?Some people just don't get it.
I read yer "profile"...well,it was part of yours anyway.....you just may KNOW my friend I'm talkin about.Came back just a couple of(maybe less)months ago...Shane Mulkey?Wouldn't THAT be somethin.
* Last updated by: blue07 on 5/17/2011 @ 2:54 PM *
ethin14
RE: Head gasket?
05/17/11 4:35 PM
all that anger for 10 hp, Hub you showed amazing restraint.
BG , things work just fine , will never have a perfect world and trying to make one will fail.
ARF! ARF! EAR Doggie!
05/17/11 6:26 PM
Down to ethinEARth,
Soldier would bounce a belly and I could not be happier I make somethingood out of his watch stand a little canna dog fooding. What others die an try is want you to think in the field. You yourself dye trying with porn even. I try but it's that old saying, "...every good deed can squeeze 10 say 12 hush puppies an flush out a few more...." Say Soldier, say nothing. LOL
justins07zx10
RE: Head gasket?
05/17/11 7:34 PM
Hub, your just a keyboard warrior, do you even have a bike? I have been working on bikes for a long time, fatass I just started messing with the 14's and was trying to get an oppinion from someone who has been around this bike a little more.
I don't have a clue about what I'm doing though, I just make all this shit up about degreeing cams,and shit right I didn't build the head on my 10 either.
I beat you never changed a damn sparkplug! I guess I'm just the only one that don't want to hear your bullshit on their thread. Did I hurt your feelings when I shot you down. I'm sorry I hurt your confidence a bit. I guess I'm just going to have to go back to 10r.net where people don't mind helping a fellow owner out.
PcIII
BMC Race
Full S/S Muzzy M10
Scotts Damper
G.I Pro w/tre
Z/G doubble bubble
16t sprocket
speedo healer
More to come...
Here ya HAND Job. Take the booroom and clean UP YEAR MESS
05/17/11 9:46 PM
Yes, I defend the FSM. To the death. Not a physicks class can stop it. You'd have a doctor'degree and I'd smoke that paper it's written on. I asked someone that hole in the head question. I said, if you held one ear closed, the other open, what is the pressure on your skull where the porn king lives?
SheWin? A sled too. Why, you too?
I've been eating longer than you, bird poop.
I just started messing with the 14's and was trying to get an opinion from someone who has been around this bike a little more.
I bet you can't get the owner'slamyouwill out of the plasstick packet.
I tried to point that out on my second postoasting.
If I asked very specific questions, I bet you's fumble the tumble right out the box of those plastic tools your parents let you play wit. I got a sandshovel.
Wait a minute. First you said you work on them more than I eat. Now you are saying you didn't hand that off cause you can do it and you wanna help your buddy's wallet out? Or you are kind of hez zoo tense like you got the tools but you are no money wrench yet. Understood.
I bet you never changed a damn spark plug!
I would have to say no. And your question was so general, I could say what year? What month, what weak sentence there guy.
I'm sorta wiping your upper lip so you can smell what you walked into. Wait for the next quotes
Yes you did. When I handed you the boom to sweep you UP with it, you parked your elbow on the top of the and then leaned there like now you are a wrenchandshit.
No, it is more I am warming up the track for you since I have no warmers needed.
I was going to put a blankie on you for the nite soil you can sleep in your shitty diapers. I figure you with the tail under you legs will be the pooper scooper catcher you be smelling up the 10r.nethey'll throw you out you coming here.
You helped yourself to the beer and I asked if it was cold enough for you. 42°F is ready to drink. Not a degree off that mark or I'd be shitting on your bike all room temp pee true?
Yes or no? Are you getting a wax job, hose job, oil change, and a beer waiting for a lubathe chainwhiffing boy you are turning out to watt becomes you? OH look at that WD-Fork In the RoDe another one up the wall LOL
* Last updated by: Hub on 5/17/2011 @ 10:02 PM *
alg8er
alg8er's Gravatar
RE: Head gasket?
05/17/11 10:23 PM
justins07zx10; "Next time I make a post please don't comment unless you can, 1st answer my question, 2nd type like a normal member on the forum."
I didn't know you were the forum sheriff! OK everybody, make sure you don't post unless you can answer all of Justin's questions, and type in short concise sentences, with all small words so little Justin can understand you, or he'll tell his mommy, and you'll be in big trouble. Oh crap! That's a run on sentence, with some big words! I didn't even attempt to answer the question either! I'm in trouble now!
dumbass
Page: 1 2 3
