Ok guys, someone else had this issue, but the discussion did not appear to resolve the issue:
A large rubber well nut was cut nearly in half and needs to be replaced... It is the larger rubber/brass well nut that secures a corner of the foreman grill to the fuel tank/airbox assembly via a longer than average fairing machine screw and is NOT the smaller more common OEM schematic part number 92015 (5mm) well nut as shown at such web sites as Babbits, this is a Kawasaki error in its parts diagrams I guess, this fuel tank well nut is much LARGER, outter diameter of rubber is much larger than the common 92015 well nuts that secure most of the fairing and windscreen bolts.....I need your help in finding a source and or correct part number for the larger mystery well nut..
ANYONE:
a) What is the OEM ordering part number for for this larger fuel tank well nut that seats the long bolt through the upper corner of foreman grill in to the airbox/fuel tank housing (on the larger OEM well nut I took out it says 1420D, but thats not an OEM part number. It is NOT 92015 as shown on OEM schematics such as at Babbits, unless there are differant version of 92015 well nuts (like 92015 - xxxx)??????
b) Where can we order these Kawasaki larger well nuts?
Thanks!
Drew
Ft Lauderdale
K636 Race
ZX14 Commute
