Thread: Top Case
Created on: 06/11/09 10:23 AM
Fit1
Top Case
06/11/09 10:23 AM
can antone tell me if i can fit the E45 simply case to the ZZR1400 on a 07 plate. Kawasaki only do the 39lt which is to small.
Fit1
RE: Top Case
06/12/09 5:49 AM
the top case is a Givi luggage top box E45 is the size eg 45 litre. Kawi only make a 39 litre case. 07 means the year my bike was made. I want to know if its possible to fit this type of top box and till use the Givi v35 panniers as well.
hope this helps you understand what im trying to do.
sok61
RE: Top Case
07/03/09 7:01 PM
Did you try the Givi website? It's probably your best source for what will or will not fit. I can't tell from your original question, but I'll assume you want to fit an E45 case to and OEM Kawasaki mount plate - for which the two are probably not compatible. Good luck.
