Thread: CLUTCH SPRING QUESTIONS
Created on: 07/21/23 05:17 PM
OZrevhead
OZrevhead's Gravatar
Sydney, Australia
07/21/23 5:17 PM
Guys,
1. What is the installed height of the stock Zx14R clutch springs? Brocks mentions 1.04" in the specs for the green springs, is this the stock height spec? Stock seat pressure is 45lb right?
I installed a Brocks Real Street kit but I think its heavier then my needs justify so I am looking to balance the pressures between this level and stock. I bought some EBC +15% springs (in transit) and a spring pressure tester, now I just need some washers/spacers to tinker with. I'm looking at EBC +40-60 thou of shim and see where that comes up at.
2. If shimming a clutch spring do the shims do at the top (like the Brocks thick spacers) or at the bottom like you would for valve springs? I guess washers at the top would be lighter due to the larger ID that they locate against?
Cheers
OLD GIRL - 2007 Black zx14, Muzzy 4:1, PCV, QS, 1" risers, 165hp so far @ 142,000km, 9.995@142........ NEW BABY - 2014 Green/Black ZX14R, Two Bros slip-ons, PCV, Dynojet QS, 1" risers, Sargent seat, Brocks clutch kit, 206 HP on dyno
RE: CLUTCH SPRING QUESTIONS
07/22/23 11:39 AM
OZ, Say it's 6 springs total. To hard to pull, triangulate 3 OEM, 3 Brocks. Washers might coil bind and tear or load the thread holes as the coil can no longer move.
OZrevhead
Sydney, Australia
RE&#x3a&#x3b; CLUTCH SPRING QUESTIONS
07/22/23 3:17 PM
Hey Hub,
Brocks says you can shim up to 242 thou (6mm) before coil bind, Im looking at 1mm shims.
See table on page 2 here:
https://brocksperformance.com/content/Instructions/ZX14/996421.pdf
Brocks green is 130lb seat pressure, Brocks purple is 47lb unshimmed. EBC may be about 49 to 52, I will confirm this when they arrive.
* Last updated by: OZrevhead on 7/22/2023 @ 3:20 PM *
07/23/23 9:56 PM
The shims I used went on the top of the spring, spring in first, then shim on top. I have a tutorial on that.
07/24/23 12:18 AM
Assist:
OZ, Okay, I see the limiter springs are not used. Did Brock say said pound gets you in the ballpark or figure start at the center and work you clutch feed up or down in pounds? No starting point, that's a lot of bike lean and cover popping.
OEM Clutch Springs:
Standard Free length: 32.1mm (1.26 in.)
Service Limit: 31.0mm (1.22 in.)
Like a valve assembly, I'd set the washer down in.
