My guess is sitting? Did you change coolant every year weather you hit the mileage first or the year plays out?; whichever comes first.
Well, 7000 miles since I bought it in May of '10, not exactly high mileage. Expand on this thought further please as there are a lot of older bikes with very low mileage I see all the time on Cycle Trader, Craig's List etc. that don't have bad waterpumps. Very likely if the owner didn't have time to ride it he most likely didn't have time to change coolant...Yes or No?
Also it seems to be leaking from the oil seal side not the coolant side of the seal. From what I can make of the parts book breakdown, there is a chamber between the two with the weephole at bottom so in theory oil should not contact the coolant seal and coolant should not contact the oil seal. Yes or No?
1. Mech Seal: This may have the face of this side damaged or cracked. The porcelain washer is pretty much bulletproof. So either the spring collapsed that pushes that seal at the end of the spring, which I doubt it.
Please explain the mechanical seal a little better, until I can actually hold one in my hand and look at it, the theory is vague. What does the porcelain washer do, it appears that it is on the back side of the pump impeller?
The other is the oil seal may have polished a groove, or the coolant etched the shaft? This is where you call the ball about changing just the seal and hope for the best.
I was thinking of that possibility too but in 7000 miles? I've seen Honda Goldwings with over 300,000 miles on the original water pump but then again, you're right about not riding this bike much. With five in the garage, maybe once, twice a week.
@BG...... good call bringing the HubMeister back on line, he's the only person who has the experience to talk the talk on some of this stuff. He's probably seen a million of these water pump failures so first person I thought to ask about it.
2021 Aprilia RSV4
2020 BMW S1000RR
2016 ZX-10R KRT
2016 959 Panigale Red
2015 CBR1000RR SP Repsol
2011 ZX-10R Ebony
2009 ZX-6R Lime Green
2006 ZX-14 Red
2004 VTX 1300C Candy Red
"For we walk by faith and not by sight" II Corinthians 5:7
