I'm looking for a clutch lever with maybe an easier pull and a little smaller feel to it. Can't seem to gel with the stocker. Anyone know of any?
Created on: 03/28/15 07:50 AM
Auron
danfzx14
RE: Most functional levers?
03/28/15 9:15 AM
Did you try adjusting the angle by loosening the clamping screws and rotating the whole assembly? Just an idea.
Auron
03/28/15 11:57 AM
I felt the clutch was a bit on the tight side but I got used to it. I don't think Pazzos make take any of the strain out of pulling the clutch. OEM levers are about 2 oz heavier than the shorties so they probably weigh about the same as the Pazzo longs. Obviously, I wouldn't recommend shorties for easier pulling.
03/28/15 11:58 AM
I got he Pazzo long levers, smaller than the stock, but not too short, however, some people have
problems with aftermarket levers, I havent yet ...
If you get them. make sure the little cylinder thing on clutch is sitting right in the clutch lever
and keep it lubed well with a good grease
zx14rider345
03/28/15 3:37 PM
I have the ASV C5's. I had all kinds of issues with them when I first got them from Moto Mummy. IMO they were not set up correctly for a ZX14 and after Moto Mummy said it was the manufactures problem I sent them back to ASV who did take care of me and sent me a correct fitting set. I still think the stock clutch lever engages the clutch a little better over the ASV's but the ASV's are nicer looking levers. Been running them for over two years now with no real issue.
yannih
04/01/15 3:20 AM
I also run the ASV C5's and have had no issue at all.
Great product and much better feel and look than the OEM's IMO.
The only thing is I would not recommend the shortys in these as they are too short ( see below pics which are longys).
Again IMO go the long versions if you go down the ASV path though ZX14rider may have something to say about that...
* Last updated by: yannih on 4/1/2015 @ 3:25 AM *
wfozx14
04/01/15 5:04 AM
I have a brembo RCS16 clutch cylinder and lever and RCS19 brake cylinder and lever. Kinda spendy but adjustable. One finger useability.
zx14rider345
06blackpearl
04/09/15 4:31 AM
I also use the ASV pricey but worth it! Zxrider how does those gold levers compare to the gold wheels? Mine are way off but I think I'm still going to use them..
zx14beast
04/09/15 7:44 AM
I actually don't like the way the asv levers fit my 14r either....
Clutch pull is not directly into the middle of the bar... it hits below center.... something you sort of get used to
but still not the way it should be in my opinion.....
by the way 06blkpearl, the gold matches nicely with Carra's anodized gold.... not sure about Oz's....the Hyperpro damper though is a much paler gold colour.... wishing I got something different for my stabilizer..
* Last updated by: zx14beast on 4/9/2015 @ 7:45 AM *
psychoninja
zx14rider345
04/11/15 8:51 AM
06 Pearl, the gold ASV's match the wheels pretty good. Not perfect but still looks great. I also have a gold GPR, gold pegs, Gold banjo's on the braided lines and gold mesh in my front CF fender and CF hugger. I like the gold!
moppedmanniemie
moppedmanniemie
