Marriage is overrated.Hi Kruz;)That a new bike there?Beautiful!GL with your radar deals.I had mine mounted on a ball mount attached inside the steering stem.Fit nicely in there,full windscreen view.Had it set so it just peeked above the smoke line on the screen.Horizontally.It did however block the view of the display,which I didn't like too much.
Worked excellently,but I took it off figuring WTH I'll take it easy on the straights and ramp her up on the curves,like you and Rookster.I mean,they can't tag ya in a curve unless you meet at the apex or therabouts.Most curves up here you can see all the way through.I mounted a 120db external speaker alongside the steering stem under there.It was loud.The detector was pretty stealth.You couldn't see it in there from any angle like from an oncoming car or someone passing.Good job with those!I tried the windscreen setup like yours.It didn't want to hold to the screen.GL with that stuff;)
Mine also captured Radar from behind.They do that up here,follow ya.Didn't think they had anything like that,but yep,they can clock ya while they're also moving.I've had em flash their lightbars a few times while they were coming in the other lane.No way could they read my speed just by lookin.
* Last updated by: Grn14 on 5/2/2018 @ 12:37 PM *
