Thread: Hot Wind Cover Pads and Brackets
Created on: 02/24/12 06:26 PM
02/24/12 6:26 PM
Hot Wind Covers and Brackets
The hot wind cover brackets inside of the side fairings may be removed as a preliminary step to removing the front directional light. They also can be removed permanently to eliminate excess weight.
Tools:
phillips head screwdriver
#8 neoprene washers (optional)
Remove foremans, ram air covers, tank fairing, lowers, upper inner fairing, side fairings and inner fairings (see Fairings Removal).
1. lay the side panel with the inside facing up. Use a phillips head screwdriver to remove the two screws that secure the hot wind cover brackets to the front directional light assy.
2. Remove the hot wind cover brackets with foam hot wind covers. Using the phillips
head screwdriver, reinstall the screws to the same holes to secure the front directional light.
If the screws do not go in far enough to hold the direction al light assy tabs tight against their mounts, thread a #8 neoprene washer onto the screw as a spacer. Reinstall the screw. Do not attempt to crush the neoprene washer as would normally be done. The plastic threads in the fairing are not strong enough for that much force.
The hot wind cover pads and brackets weigh 10.2 oz.
Install inner fairings, side fairings, tank cover, ram air covers, foremans and lowers(see Fairings Removal).
* Last updated by: Rook on 4/25/2012 @ 12:01 PM *
runr2940
runr2940's Gravatar
RE: Hot Wind Cover Pads and Brackets
08/27/12 3:29 PM
Thankfully the new 2012s come without these...
2012 14R black, full Yoshi R55 exhaust (powdercoated black), PCV, Ballistic Evo 12-cell battery, PAIR mod, ddmTuning HIDs, Yoshi frame sliders, ZG DB windshield, CoreMoto brake lines, LSL brake/clutch res, MagKnight tank protector, Woodcraft spool sliders, custom fender elim, Puig alum chain guard, Clear Alt smoked turn signals, Pazzo racing levers, Throttlemeister bar ends, Grip Puppies grips, Powerlet power socket, Saddlemen Tech seat, CNC alum gas cap, Bridgeport valve stems, Tamper-proof Murph's oil cap, Sato rearsets, magnetic drain bolt
08/28/12 2:42 PM
That is a nice improvement if the 14r doe s not need them. Must say, my bike with all the heat insulation removed feels pretty hot on my legs.
