Romans wrote: Rook did you strip a screw ?
No. I just looked at the screws and I see no burs on the x slots at all. When you take tem out, the key is to keep the hot screwdriver in the slot a long time. I don't think you can overdo that. I'd estimate that if you heat the screwdriver up as I mentioned above, quick touch it to a bead of water or wet cloth to test for adequate temp, it will stay plenty hot for at least ten minutes. Heck, leave it in for 10 minutes on the first screw. You can't hurt it by transferring too much heat. I mean, the thing isn't going to be glowing cherry red or anything. I removed my flies in below zero weather out in the garage. That screwdriver will stay very warm a long time and you do not need to rush.
If you're really serious about getting them out without stripping, why not practice? Get a 3/16" steel plate, drill and tap threads, order some fly screws, blue locktight 'em, let 'em sit a few days and do a trial run. That should show anyone how easy it is. Maybe strip one on purpose and see what it takes to get it out.
BTW Bill, if you have a G2, I'm sure you'll be just as satisfied had you left them in. You can always come back to it just for fun. You only pick up a tiny bit more power below 3K in 1st gear and I don't think anyone can really use all the bike has there flies in. Drag racers seem to favor flies in. You thinking you might be able to bolt ahead quicker if you're riding it soft in 5th, 6th gear if you pull flies? No. They're already open in those gears any rpm.
If you leave 'em in, nobody will know except you. Kawi did a good job safing up the bike for low speed street turns (you can still get yourself in trouble there with flies in, mind you) while maintaining an excellent race launch with flies in. It's cool to know they're gone but it really isn't worth any frustration if you have trouble getting them out of a G2.
* Last updated by: Rook on 4/1/2009 @ 9:39 PM *
