Thread: H2R Super Charger
Created on: 02/20/15 06:45 PM
redboot
redboot's Gravatar
H2R Super Charger
02/20/15 6:45 PM
Does any body know the propulsion method of the super charger? At 22,000rpm I doubt that it is chain or belt driven.
Perhaps gears, planetary, or fluid?
Current rides
2015 300 Ninja
1994 ZX9R Ninja
2008 ZX14 Ninja
1974 Triumph Trident
2006 Ducati 999R
RE: H2R Super Charger
02/20/15 11:13 PM
Planetery
Fowvay
Fowvay's Gravatar
02/21/15 4:48 AM
According to the technical data from Kawasaki on the design, "Kawasaki uses a step-up gear system in addition to a planetary gearset to drive the supercharger's impeller shaft. The step-up gear set is driven directly by the H2's crankshaft (via chain) and spins slightly higher than engine speed. The chain drive takes power from there to a planetary gear set that resides inside the supercharger's housing. This combined effect is to turn an engine speed of approximately 14,000 rpm into an impeller speed of 130,000 rpm. A planetary gear set is one way to provide a significant change in gearing within a small space."
This information is provided via Kawasaki technical publications.
2012 ZX-14R Green
02/24/15 5:54 PM
I'm wishing for Varoom and not Kaboom!
