Rigatoni Woodsman Style Bring a large pot of salted water to boil for pasta. Slip the rigatoni into the Celine Mini Belt pasta water, and cook until al dente.
Heat the olive oil in a large skillet over medium heat. Add Celine Handbags Outlet the onion, and cook until softened, about four minutes. Add the sausage, and cook, crumbling with a wooden spoon, until it is no longer pink, about four minutes.
Add the mushrooms, then cover, and cook until the mushrooms release their juices, about two minutes. Uncover, and add the sage and tomatoes. Bring to a simmer, sloshout Celine Cabas Tote the tomato can with one cup pasta cooking water, and add it to the sauce, along with salt. Bring the sauce to simmer, cook, uncovered, until thickened, about 10 minutes.
Once the Celine Trapeze sauce is thickened, toss in the peas and scallions. Cook until the scallions wilt, about two minutes. Pour 1 cup pasta water and the heavy cream into the sauce. Bring to a boil, and cook until thickened, about two minutes.
When it is cooked, remove the pasta with a spider and add directly to the sauce, tossing until the pasta is coated. Celine Bag You from heat and sprinkle with the grated cheese. Toss again, and serve immediately.
NotesBe sure to shake off as much water from the mushrooms after washing them. You may need to simmer for much more than 2 minutes after adding the tomatoes and mushrooms for the sauce to thicken. Otherwise you may end up with too much of a thin pasta sauce at the end. I've tried reducing the heavy cream to reduce the PointsPlus value, but Celine Handbags Online it just doesn't work. I'm open to suggestions. Though this dish is delicious and worth all 10 Points!
http://www.airjordanmvp.com/mlb-hats-c-185/
http://www.lhbon.com/celine-trapeze-c-13_18/
http://www.cellphonecasesale.com/ipad-mini-cases-c-41/
http://www.airjordanmvp.com/air-jordan-10-c-84/
