No, Romes. The stockers are a 5 bolt pattern with 6mm (I think?) shank bolts that have a shoulder. The CZ rotors are a 6 bolt pattern with 5mm shank and no shoulder. The shoulder prevents you from overtightenning and stripping threads. The larger shank can take the torque that a rotor bolt SHOULD have applied to it.
Some day, I may drill and tap a 6mm thread and prolly cut a recess to accept a shoulder. I think CZ should have had the sense to do this in the first place. The 5mm bolts they use are more appropriate for fastenning fairings than rotors.
nope, front CZ rotors will not fit a stock bolt pattern. Cz is designed for 6 bolts that are smaller, shorter and without shoulder. Saves a few ounces though.
front and rear OEM rotor bolts all together (14 bolts) weight
front CZ rotor bolt weight
rear rotor bolts ProBolt Ti (ZX-14 OEM copies) I used on rear CZ rim with Galfer rear rotor (notice the shoulder and the larger shank)
* Last updated by: Rook on 11/14/2013 @ 6:30 PM *
