Uhmmm...this is Gas'd...You left out...WOT model PC are u using?You understand how the thing works.Your LAST statement(s)....about a 'borrowed map'...what does that mean?And...secondly...building a 'one off'....what is that?Every tuner has to 'build' a map...from the baseline.Factory settings if you will.And who knows what those are?The tuner's adding or subtracting...but he's only adding or subtracting from the already 'set' numbers.Zeros you know mean...NO CHANGE from factory.Those do not show you how much fuel is going in.2% increments...that's how it's added or taken...maybe even more precise now with the PC V.Trimming the fuel cells on each cylinder and each rpm(s)and ignition fire time.
"you can borrow"....you mean,like downloading from a site?Or do you mean...borrow...like copy and readjust to how you want it.They're ALL borrowed in that sense.UNLESS...the tuner KNOWS what the factory fuel values are behind those zeros(locked up in the ECU).
* Last updated by: Grn14 on 5/9/2012 @ 7:55 PM *
