So the gas pumps in the Miller paddock area had some REAL high octane gas -- 110 octane. It was about $8.50/gallon.
Can this be run in a ZX-14 without any tuning changes? Might be fun to try it sometime if it wouldn't hurt the motor... -bg
Created on: 04/19/10 08:16 PM
bgordon
Forum AdministratorLocation:
9secondsflat
RE: 110 Octane Gas?
04/20/10 3:30 AM
your bike will run much slower at the drag strip if its stock, you dont have the c/r...the bike would need more timing and much more c/r...bottom line for 8.50 buy yourself a nice 6 pack of your favorite imported brand of beer.
even in my turbo busa running 10psi with stock c/r i would only add at most a half a gallon to three full gallons in the tank and that was only on the hottest days 95+ at the drag strip..otherwise 93 worked fine..
TaintedTattoo
RE: 110 Octane Gas?
04/20/10 11:25 AM
It is my understanding that you will make the most horsepower with the lowest octane fuel you can gete away with running without detonation,, so if its a stock motor you probably would see very little advantage, although you might go faster because your wallet is much lighter.
* Last updated by: TaintedTattoo on 4/20/2010 @ 11:27 AM *
Slowninja
RE: 110 Octane Gas?
04/20/10 3:05 PM
stock bike, run 87 or 89 octane. period.
I run 116 in mine heh heh heh
