Thread: Swingarm extensions
Created on: 06/24/09 12:51 AM
AZ14
Swingarm extensions
06/24/09 12:51 AM
Hopefully you all can follow along with my thought process. If you lower the front end (no more than 1/2" from what I've read) you get a faster steering. However, you loose suspension travel.
If you put the 3"-6" swingarm extensions on you will raise the rear approximately 1/2"-3/4" inches from what I can estimate. This would have the same effect as lowering the front end without the disadvantage of decreasing the suspension travel.
Without doing the measurements and calculations I thought I would ask for all of your input.
