may be a silly question but... you started at the collectors,added the header pipes correct? did you leave everything loose? important that everything is left loose until you get you lowers on and adjust if needed to not be to close to the plastic. plus pipes will not go together right if you tighten as you go. heres some pics of mine dont know if they will help or not
