Got all the new parts on with NO breakage. Whoooo, what a relief. New side fairing and new dash boards. Now I gotta wait for the NINJA emblems to come in as they are sold as a seperate part. And those emblems are expensive as HELL, too.
I know this fairing so well and every tab, bolt pushipin, direction to pull, push...........I can now do it in my sleep.
Here is a hint a learned the hard way, but one I hope will prevent someone else from busting off their precious and expensive fairing tabs.........Its a safe way to get the grommets on the tank cover to pop into those brittle tabs I broke before.
1. Don't bolt down the Foremans. Merely pop the front end in place and leave the foreman grommets not popped in and leave all three bolts (two big sliver ones and the small black one) out, for now.
2. Then when you start to put that tank cover on and are bout to attempt to pop them tank cover knobs in those brittle mid fairing grommet tabs, carefully and gently pull the Foreman grill out just enough to get your hands up underneath them, and use your fingertips to support the brittle tab on the back, as you maneuver the tank pad tab into the brittle mid fairing tab grommet, while also making sure the upward pointing tab on the forman is getting aligned in the slot just above it in the bottom of the tank pad. If you have big thick hands, this probably wont work, but it did for me as my hands are long. But be extra careful and gentle, as its like a brittle puzzle in that area.
I have found this to be pretty much the ONLY way to ensure you haven't busted them tabs off. As I said before, I regrettfully say alot more of us have broken them than realize, cause once they break off, you don't even know it. (but then again, if you don't know it, who cares? LOL)
Anyway, hope this helps. .
* Last updated by: ZX14MAN64 on 12/13/2012 @ 8:44 PM *
