So I picked up a 2006 ZX14
I'm going to assume you bought a bike that ran and you rode away with it. Or did you tow it home?
and he said he was riding and down shifting and all of a sudden his back wheel locked up and the bike wouldn’t go in any other gear.
No doubt the bike can leave from a dead stop and move away in any gear. So you rode it home in a single year, now you're here.
Bike won’t roll with clutch in so everything is pretty much locked up.
To separate the clutch from the back wheel is to keep bumping the bike back and forth with clutch lever in until the plates break loose.
Also the bike cranks and runs great.
So you can pull the clutch in and the bike does break the clutch loose from the back wheel.
Clutch goes in all the way. Shift lever moves up and down.
With the oil cap off, you can watch the pressure plate move out. Shift lever moves up and down yes, but can you shift down?
Or are you wondering why you can't hand shift the lever thru the gears? So bottom line, did you buy a bike stuck in gear?
