Thread: HELP! how to bleed my radiator
Created on: 04/18/09 06:03 PM
jlcumb2
jlcumb2's Gravatar
04/18/09 6:03 PM
Hey im out of town on a ride no manual no shops open. I was wondering if any body cpuld help me try to figure out how to bleed my radiator. We have narrowed it down to bleeding the radiator. I can find the nipples
can some one helop please
zx14 white bike + white wheels= cleaner than the board of health
2007 hayabusa black out brocks and vortex everything..
Nightmare
Nightmare's Gravatar
RE: HELP! how to bleed my radiator
04/20/09 10:27 PM
FYI, you don't need to actively bleed a cooling system, most systems (and i'm assuming the ZX14 is simillar) have the radiator as the high point in the system which will force the majority of the air to the cap, when the engine heats up the air is forced into the overflow resivor. When the engine cools the excess coolant (minus the air) is sucked back into the radiator.
Now would be a great spot to start chatting about vapour lock in the cooling system and the possible impact it could have on the operation of the thermostat, hot spots on the engine block, etc... but i'm lazy so i won't get into it, just make sure you try and get rid of as much air as you can before putting the cap on the rad and going out for a ride.
04/21/09 10:53 AM
i CHEAT BY DRILLING A 1/8 HOLE IN THE THERMOSTAT IF IT DOES NOT ALREADY HAVE ONE. SOLVES THE PROBLEM OF GETTING TRAPPED FROM THE HOSE THAT GOES FROM WATER PUMP TO THERMOSTAT.
ON MY ZRX'S YOU HAVE TO BLEED AT THE WATER PUMP AND THERE IS A BLEEDER VALVE IN THE T-HOUSING. IF YOU DO NOT DO BOTH IT MAKES A NICE LITTLE AIR POCKET WHICH IS WHY I DRILL A HOLE.
jlcumb2
jlcumb2's Gravatar
05/07/09 5:31 PM
Thank you all so much i greatly appreciate your help. thank you so much
