Hey y'all.
New (to me) ZX14 owner here. For those with the ABBA stand, how wide is it at the base where the supporting feet stick out?
Before I add to cart I'd like to know if it will work while on my motorcycle lift.
Thanks in advance!
Created on: 03/12/23 11:56 AM
smoke4ndmears
RE: ABBA Width at Feet
04/06/23 6:37 PM
The lift arm is ~27.25". If you need more precise I can measure. I have the full abba superbike kit and kaboodle, front lift arm (highly recommended) and the roller jobby if yuo need other measurements
The way pivot lifts work, I do not recommend using a jack or hoop stands to lift the front while using the pivot stand.
smoke4ndmears
04/07/23 4:55 PM
There's a possibiity it still may work with your lift. Because you slide the other bracket on and it can probably be 3" from the open side. So it probably would fit on your lift but it would have a bit of the base sticking off at 26".
You'll see what I mean, not sure I'd chance it cause it would probably be pretty close but you'd be a better judge since you have the lift.
* Last updated by: VicThing on 4/7/2023 @ 4:56 PM *
