HAS ANYONE EVER HAD SUCH CLUTCH PROBLEMS?
First off... my bike has over 13,500 miles and has been through three sets of new clutches, fibers and Brock's stiffer springs. I am a rookie that flipped my '06 zx14 at the starting line of the 1/4 mile. I was racing my friend that has an '06 mid 8 second ZX10. The fastest I have ever run was 9.65 - extended, lowered and power commander. I launched at 10,000 rpm as normal. But... soon realized that I forgot to strap the front down as she bounced straight up. I went to grab the clutch lever to bring her down and at that time my index finger slipped off causing my right hand to try and pull myself back on to the bike to get another grip. At that time my right hand, holding the throttle rolled back - I'm sure you know what's going to happen. To save myself from being body slammed by my "BIG GIRL" and having the windscreen break a few ribs or test the strength of my use-to-be rock solid abs - I pushed away clearing the destruction and landing on my "assets". My reason for telling you all of this is not to continue to embarrass myself but, to give any willing tech the gist of what all has happened to my "BIG GIRL".
Well... after fixing the few parts that got smashed, I got back on the road. After thirty miles or so I noticed that the clutch was still slipping when I would try to get into it. So even though the steels, fibers and springs were fairly new I took them out and noticed that they were not blue, burnt or worn. I still replaced all (2.6) steels,fibers and Brock's springs with new ones (SOAKED THE FIBERS IN 5W20 OIL OVER NIGHT). The only other thing that I have done was change the oil to Royal Purple 10w40 motorcycle oil. I put everything back together the next day and she still slipped. At that point I took the clutch apart and removed a few steels and fibers and "DOUBLE STEELED" her and put everything back. All then worked well and I put 400 plus miles before I had problems. At a traffic light I had the clutch pulled in but when I went to take off and let the clutch out she did not engage and go. I pulled the lever several times and finally she connected but it happened again a few miles down the road but would not connect. At that point I got a trailer for my queen and took her home. Any and all advice to help me fix this problem would very much be appreciated.
* Last updated by: wetzx14 on 10/20/2009 @ 8:07 AM *
