Thread: F (y) I Hub
Created on: 05/03/09 05:40 PM
nicezx7
nicezx7's Gravatar
F (y) I Hub
05/03/09 5:40 PM
Well Hub I went for a ride today and my FI error came on where I was able to check the code #. The code is 25, which looks like a short or open on the gps. Is this directly due to the $0.27 tre mod, or did I do something wrong. I did the mod over again after your last advice, I know for sure it is a good connection. I do get the 6 in every gear, and the nuetral light works perfectly. The bike never misses a beat, is all still well or did I botch the job?
Thanks Hub, your time is greatly appreciated as always.
It feels nice out.........I think I'll leave it out.
nicezx7
nicezx7's Gravatar
RE: F (y) I Hub
05/03/09 6:27 PM
Well Hub, my assometer tells me the bike is smoother and more responsive below 4000 rpm with this mod.....however, I kinda feel as though the bike does not have the top end hit it had before. I can't tell if this is just me getting used to the bike, or if the bike itself is not reacting the same. I remember when the flies were in, once I hit 6000 rpm wot, the bike seemed other worldly fast. After the flies out mod the down low power was appreciated, but for some reason the top end never felt as fast. Again, this could just be me, and I don't know exactly what the ecu makes of these mods.
nicezx7
nicezx7's Gravatar
RE: F (y) I Hub
05/04/09 1:44 PM
Hub, I returned my bike to oem on the gps. After looking at some of your other posts, it seems as though I may put my flies back in. Other than the obvious usable power gain down low, I am starting to think the bike runs better up top with them in. Am I correct or just completely lost?!? Thanks Hub
nicezx7
nicezx7's Gravatar
RE: F (y) I Hub
05/04/09 7:35 PM
Thanks Hub!
darryle
darryle's Gravatar
RE: F (y) I Hub
05/05/09 3:10 PM
Hub first thing I did to my 07 was a PC it really smoothed out the throttle Dyno jet map for stock bike.N ext was a full system.I like that 6 grand hit.I think that with flys in the bike is climbing out of a hole so the 6 grand hit is more fun .
